Convert WGS to UTM
7718
6
02-24-2015 08:44 PM
ShyamanthaSubasinghe
I have number of City locations which collected from Google Earth. They are in WGS coordinate system. I need to convert them  into UTM coordinate system,separably. Is there any procedure to find respective UTM  zone for each city/ place in ArcGIS?
KishorGhatage
Step 1
1 .Navigate to the following location using catalog window / ArcCatalog
C:\Program Files (x86)\ArcGIS\Desktop10.2\Reference Systems
2. In a new arcmap session add "utm.shp" from the above location
3. Add your location layer ( which is in WGS)
4. Use Identify tool and click on the city
5. You will find zone in the identify window
Step 2
To reproject the data from WGS to UTM you can use Project tool (Data management).
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Hope this is helpful
Kishor
KishorGhatage
Step 1
Step 2
Kishor
Thank you very much for your reply
I want to find out respective UTM zone for each cities..?
Thank you very much Kishor Ghatage..It is very helpful for my work
NeilAyres
MVP Frequent Contributor
Just a picky terminology issue....
You can't actually have your data IN WGS84. Because WGS84, by itself, is not a coordinate system.
It is a datum & ellipsoid (& a geoid).
You can have it IN GCS_WGS84 (geographic, based ON the WGS84 datum / ellipsoid).
Then project it to a projected UTM zone based on the WGS84 datum.
Thank you for explanation
MelitaKennedy
Esri Notable Contributor
An algorithmic way to determine the UTM zone is here and reproduced below. I originally cribbed it from Chuck Gantz.
ZoneNumber = floor((LongTemp + 180)/6) + 1;
if( Lat >= 56.0 && Lat < 64.0 && LongTemp >= 3.0 && LongTemp < 12.0 )
ZoneNumber = 32;
endif
// Special zones for Svalbard
if( Lat >= 72.0 && Lat < 84.0 )
if  ( LongTemp >= 0.0  && LongTemp <  9.0 )
ZoneNumber = 31;
  elseif
( LongTemp >= 9.0  && LongTemp < 21.0 )
ZoneNumber = 33;
  elseif
(LongTemp >= 21.0 && LongTemp < 33.0 )
ZoneNumber = 35;
  elseif
(LongTemp >= 33.0 && LongTemp < 42.0 )
ZoneNumber = 37;
  endif
endif
(I'm sure there are similar posts on GeoNet, but this is the first one returned by Google.)
