Comparing results of 2 scenarios
1308
05-29-2017 09:50 PM
MeldebekovaGauhar
I have 2 shapefiles of the same watershed with sediment export values (from each subwatershed) - one for baseline LULC and another for riparian reforestation scenario LULC.  How can  I generate a map showing the differences (increase/decrease) of sediment export?
Tags (1)
JayantaPoddar
You could perform a Union.
The output will have Attributes of Sediment Export Values from both shapefiles. Add a new field and calculate the difference (FLD_A - FLD_B) using Field Calculator.
You might like to label/symbolize the new shapefile based on the above values.
Think Location
JayantaPoddar
Think Location
MeldebekovaGauhar
Thank You so much! You helped me with my thesis so many times:)
JayantaPoddar
I am glad I could help!!!
Think Location
