Hi Pam,This is code I use in an application (in VB.NET, ArcGIS 9.2) where the user can select whether to merge polygons smaller than a specified area with the largest adjacent polygon or the polygon with the longer adjacent border.
Friend Sub EliminateSlivers(ByVal m_app As ESRI.ArcGIS.Framework.IApplication, ByVal pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer, ByVal MMU As Double, ByVal EliminateType As String)
Dim IsEditing As Boolean = True
Dim pDataset As ESRI.ArcGIS.Geodatabase.IDataset
Dim pEditor As ESRI.ArcGIS.Editor.IEditor
Dim pEditLayers As ESRI.ArcGIS.Editor.IEditLayers
Dim pFCursor As ESRI.ArcGIS.Geodatabase.IFeatureCursor
Dim pFeature As ESRI.ArcGIS.Geodatabase.IFeature
Dim pArea As ESRI.ArcGIS.Geometry.IArea
Dim pAdjFeature As ESRI.ArcGIS.Geodatabase.IFeature
Dim pTopoOp As ESRI.ArcGIS.Geometry.ITopologicalOperator
Try
pDataset = pFLayer
pEditor = m_app.FindExtensionByName("ESRI Object Editor")
If pEditor.EditState <> ESRI.ArcGIS.Editor.esriEditState.esriStateEditing Then
IsEditing = False
pEditor.StartEditing(pDataset.Workspace)
End If
pEditLayers = pEditor
pEditLayers.SetCurrentLayer(pFLayer, 0)
pEditor.StartOperation()
pFCursor = pFLayer.FeatureClass.Search(Nothing, False)
pFeature = pFCursor.NextFeature
Do Until pFeature Is Nothing
pArea = pFeature.Shape
If pArea.Area < MMU Then
If EliminateType = "Border" Then
pAdjFeature = GetLongestBorderAdjacent(pFeature)
Else
pAdjFeature = GetLargestAdjacent(pFeature)
End If
If pAdjFeature IsNot Nothing Then
pTopoOp = pAdjFeature.ShapeCopy
pAdjFeature.Shape = pTopoOp.Union(pFeature.ShapeCopy)
pAdjFeature.Store()
pFeature.Delete()
End If
End If
Loop
pEditor.StopOperation("Merge")
If Not IsEditing Then
pEditor.StopEditing(True)
End If
Catch ex As Exception
ExceptionMessage(ex, "Eliminate Slivers")
Finally
Release(pFCursor)
End Try
End Sub
Private Function GetArea(ByVal pArea As ESRI.ArcGIS.Geometry.IArea) As Double
GetArea = pArea.Area
End Function
Public Function GetBorderLen(ByVal pPoly1 As ESRI.ArcGIS.Geometry.IPolygon, ByVal pPoly2 As ESRI.ArcGIS.Geometry.IPolygon) As Double
Dim pTopoOp As ESRI.ArcGIS.Geometry.ITopologicalOperator = pPoly1
Dim pGeo As ESRI.ArcGIS.Geometry.IGeometry = pTopoOp.Intersect(pPoly2, ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry1Dimension)
If Not pGeo.IsEmpty Then
Dim pPoly3 As ESRI.ArcGIS.Geometry.IPolyline = pGeo
Return pPoly3.Length
Else
Return 0.0
End If
End Function
Friend Function GetLargestAdjacent(ByVal pFeat As ESRI.ArcGIS.Geodatabase.IFeature) As ESRI.ArcGIS.Geodatabase.IFeature
Dim pSF As ESRI.ArcGIS.Geodatabase.ISpatialFilter = New ESRI.ArcGIS.Geodatabase.SpatialFilter
Dim pFC As ESRI.ArcGIS.Geodatabase.IFeatureClass
Dim pFCur As ESRI.ArcGIS.Geodatabase.IFeatureCursor
Dim pFeat2 As ESRI.ArcGIS.Geodatabase.IFeature
Dim pLargestFeat As ESRI.ArcGIS.Geodatabase.IFeature
Dim dMaxArea As Double
Try
pSF.Geometry = pFeat.Shape
pSF.SpatialRel = ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum.esriSpatialRelIntersects
pFC = pFeat.Class
pFCur = pFC.Search(pSF, False)
pFeat2 = pFCur.NextFeature
Do Until pFeat2 Is Nothing
If pLargestFeat Is Nothing Then
pLargestFeat = pFeat2
dMaxArea = GetArea(pFeat2.Shape)
Else
If GetArea(pFeat2.Shape) > dMaxArea Then
End If
End If
Loop
Return pLargestFeat
ExceptionMessage(ex, "Get Largest Feature")
Return Nothing
End Try
End Function
Public Function GetLongestBorderAdjacent(ByVal pFeat As ESRI.ArcGIS.Geodatabase.IFeature) As ESRI.ArcGIS.Geodatabase.IFeature
Dim pLongestBorderFeat As ESRI.ArcGIS.Geodatabase.IFeature
Dim dMaxLen As Double
Try
pFC = pFeat.Class
If pFeat2.OID <> pFeat.OID Then
If pLongestBorderFeat Is Nothing Then
pLongestBorderFeat = pFeat2
dMaxLen = GetBorderLen(pFeat.Shape, pFeat2.Shape)
Else
If GetBorderLen(pFeat.Shape, pFeat2.Shape) > dMaxLen Then
End If
End If
End If
Loop
Return pLongestBorderFeat
ExceptionMessage(ex, "Get Longest Feature")
Return Nothing
Finally
Release(pFCur)
End Try
End Function
