I have not been able to change the properties for attribute fields that I manually add. For example I add in a field named Acres so that I can calculate the size of a certain polygon. These polygons are normally small so the acres are tenths so I go into field properties > Numeric > number format and set decimal places to 3 and I can't get the number format setting to take effect in the attribute table.
Is this because I add the field myself?
SW
