Changing data source of address locators
924
08-22-2019 08:45 AM
RachelCohen2
I have a few address locators that originally used data from a file geodatabase.  I would like to repoint these locators to the same layers in an enterprise geodatabase instead.  Additionally, as these layers are sometimes edited, I would like to create a script to automatically rebuild the locators to reflect the changes.  I was able to manually repoint the locator data sources to the enterprise geodatabase.  However, every time I attempt to rebuild, I get the error "The address locator needs to be repaired in order to be rebuilt.  Do you want to proceed with repair?"  When I say ok, it opens the locator's properties with a red X next to the data source (which is in the format Database Connections\MyDatabase.sde\fileName).  I will manually repoint it to that exact same data source.  It will be fine with that, allow the rebuild, and the updated features will appear in the locator.  However, the next time I try to rebuild, same issue.
If I try to use the Rebuild Address Locator tool in ArcMap, it says Error 000005: Could not open the address locator.  Then if I try to rebuild or open the address locator, it will say that it can't open the address locator because it was made in ArcMap 9.2 or earlier (it wasn't, it was made in 10.3).  This appears to permanently break it and all I can do is delete it and recreate it.  This happens even when I stop the services that use the locator and make sure all relevant files are closed.
I am able to successfully rebuild the address locators manually, and it will work, though afterward it will tell me that it's broken.  However, I'd like to be able to automate this process so that the locators will be rebuilt whenever the source data is updated.  Everything works fine when using the data from the file geodabase but the problems start when I switch to the enterprise geodatabase.  The address locators are located on the C drive of the server where the geocoding services are published.  The file geodatabase is also on the C drive in the same folder (but the locators aren't in the geodatabase).  The enterprise database is in the Database Connections on the same server.  Do I need to move data around or use different file paths?
Any help would be greatly appreciated.
by Anonymous User
Not applicable
Thanks for your question Rachel. Looking at what you're having an issue with this question might be better suited to either a product or topic based space such as Managing Data or Geodatabase. Here in the GeoNet Resource Hub the questions are primarily focused on using GeoNet and interacting with content.
Here are some instructions on how to move your question which should hopefully connect you with the right experts in the right place to get help Moving Content. You can see a list of all of the communities places available here which you can search based on the product you are using or the general topic area your question relates to. Hope this helps.
RachelCohen2
Thanks, I moved it!  Sorry, I was kind of overwhelmed when I saw all the location options and wasn't sure which one to pick.
by Anonymous User
Not applicable
Thanks Rachel, glad you were able to move it. Sorry you felt overwhelmed, there are a lot of community places out there, but we're here to help you find the right one.
MarkusRasmusson
Did you find a solution to your problem? Reason why I'm asking is that I have a similar issue at the moment...
