I am editing some parcel overlaps in a single polygon feature class. I want my Fix Topology Error tool to display a field other than the polygon OID when using the automatically available fixes; Merge in all my cases for this task.
I currently have to identify the polygons, observe the flash and translate the OID to the proper record with the field attribute I want to make my merge choice on. Changing the symbology and labels doesn't get the job done with the topology errors on top no matter how I set the displays.
If the merge fix with the Fix Topology Error tool would just display a different field other than OID, then my selection for which is the right merge would be so much easier. For learning's sake I would hope this could be applied to all available automatic fixes.
Is there a setting anywhere, I did not see one in all the general places I would think to look?
