Change Name of Global ID field?
3576
12-12-2011 10:26 AM
DerrickFrese
I have a File Geodatabase Feature Class with a Global ID field.
Anybody know if you can change the name of the Global ID field while retaining the field's properties?  I would like the field to be called "Segment_ID", but to act as the Global ID field normally does.
Thanks.
HeatherMcCracken
You cannot change the name of the existing GlobalID field.
However, to get the result you want, there are 2 sets of steps you can follow depending if you need/want to preserve the existing GlobalID values in your data, or if its ok to assign new GlobaID values to your rows.
PRESERVING GLOBALID values:
1) Create a new GUID field called "Segment_ID"
2) Calc the values from your GLOBAL_ID field into the Segment_ID field -
3) Delete the GlobalID field using the code in the help doc below (IClassSchemaEdit3::DeleteGlobalID)
4) Register the Segment_ID field as a GlobalID field (IClassSchemaEditEx::RegisterGlobalIDColumn)
If you DON't need to PRESERVE current GlobalID values
1) Delete the GlobalID field using the code in the sample below
2) Add a GlobalID field using the code, passing the desired name for the field as an argument. ( (IClassSchemaEdit3::AddGlobalID)
Help Docs with sample Code:
Adding and deleting GlobalIDs:  http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/d/000100000068000000.ht...
Copying or loading data while preserving GlobalID values:  http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/d/00010000019v000000.ht...
