Cannot write a non-linear feature to a polyline feature class
3829
02-16-2011 09:33 AM
NelsonDe_Miranda
Occasional Contributor III
I am using the Geometry Coercer to convert a polygon feature to polyline (both ESRI Geodatabase Feature Classes).
However, an error in the output dialog always states:
Any help is appreciated.
Cheers,
Nelson
DeniseKing
Hi Nelson,
One suggestion, check the parameters of the destination type via Feature Type Properties window, does changing the Allowed Geometries to "geodb_polygon" result in correct output or does it generate same error? The GeometryCoercer transformer can't be directly used to convert donut polygons to  lines. If you need to do this, extract the donut parts first using the DonutHoleExtractor transformer.
Denise
NelsonDe_Miranda
Hazaa!
That worked wonderfully, managed to feed my office with all those extracted donuts.
Thanks Denise.
- Nelson
