cannot find data folder that constains postal_us
1042
07-23-2012 07:44 AM
JohnGrenci
Hello, in the geocoding tutorial, in exercise 2, 'creating a composite address locator'on page 8, it to says to repeat step 4, and navigate to the data folder.  however, I cannot find it.  I searched on my computer, and cannot find anywhere.  could I have not gotten everything with the original download of files?  can anyone help?
thanks
John
LucasDanzinger
Esri Frequent Contributor
Hi John,
This should be in your ArcTutor data, which should install to <C:\ArcGIS\ArcTutor\Geocoding> by default. If you do not have ArcTutor data or do not see this one specific file, you might want to try re-downloading the data. You can get it in the Software Downloads section of your Customer Care Portal.
JamesGilmer
Im experiencing the same problem... the postal_us data is not the Atlanta.gdb in the Geocoding folder or any of the other folders under ArcTutor. And it's not a download issue -- in installed the tutorial data from a DVD.
FabienAncelin
New Contributor II
Confirmed. Same issue on my side. It is simply not included in the tutorial data. At least for my version, which is 10.5.1.
FabienAncelin
New Contributor II
I have observed that issue as well with my ArcTutor data using the 10.5.1 setup. As an alternative, the data is on ArcGIS online with the locator. https://www.arcgis.com/home/item.html?id=ca11a1f63e9a40c781b4071fdb7b017a. It can also be searched using the title ArcGIS Geocoding Tutorial Data
Best regards,
Fabien
