can not load/import data to geodb
387
02-03-2011 05:10 PM
tongkimongki
Hi all,
I have exported a fc, name it FC1, out from a geodb... then i create a new geodb and import it back again (FC1 was the first fc that I import into this new geodb). It was a success. Then I import more fc's into the new geodb. All were successfull.
Now, for a reason, I want to import FC1 again into this new geodb. But I just cant do it, only 4% out of 37000 records are successfully imported... Using tool "feature class to feature class" the error is "error 000372 : spatial reference for output is invalid, please update to allow output to become valid" Why ? i have followed the work-out from the help, but the error is still the same. I have recalculated the spatial grid index but the resulting spatial index is always the same as the original spatial index.
The only way I am able to import it is when the geodb was new (fresh)... but when the geodb has some fc in it, it just wont be imported. I have tried many ways, using LOAD, using xml, import from shp etc but they all failed.
how can i import this particular fc ?
many thanks
iam using oracle 10gr2 , arcsde 9.3, and desktop 9.3, win 2003 server
thanks
ArnePallentin
New Contributor III
check if you have enough table space, it could be that you are just running out of storage in ORACLE
Arne
tongkimongki
Thanks for replying....
If this is about space, how come i was able to load/import/export other fc with more data than the fc that i was trying to load/import ?
I made another fc that contain just the envelope of the fc that i want to load. I used tool "feature class to envelope" and than load/export this. It has more data than the original fc (41000 vs 35000)
And by the way, I set the tablespace to unlimited and auto-extend.
thanks
tongkimongki
Hi Arne,
I just tried your solution. It worked. I added a new tablespace and I was able to load this particular fc.
I just don't understand what happened... before I added a new tablespace, i was able to load a fc that has more data than the one i am trying to load, thats why i ruled out your suggestion.
Why does the autoextent of tablespace failed ? Its suppose to increase the capacity of the tablespace right ? and also, why the error doesnt tell me that its about tablespace, instead it tells me about incorrect grid size?
Anyway, thanks alot. case closed.
