Can columns be set and kept as read-only in a File Geodatabase feature class?
1036
12-06-2016 06:06 AM
Alena
New Contributor III
I saw that they can be set as read-only in an ArcMap session, but apparently is only for that session and not for the file geodatabase. It will reset when added to another ArcMap session. I want one column as editable and the other columns locked as read-only. Thanks.
