Calculate Statistics Completes but doesn't Populate
764
03-24-2014 06:34 AM
ElizabethKelly
I have a LiDAR raster (GRID) that I would like to calculate statistics on so I can generate contour lines and hillshades. The Calculate Statistics tool completes smoothly but does not populate the properties table with any statistics. I tried it in both Map and Catalog. Has anyone else had this problem or know how to get past it?
ArcMap 10.1 with spatial analyst, Windows 7 64-bit
NeilAyres
Check the file permissions using the normal windows explorer. You say this is grid format, so the directory above where the data is located as well.
You could also load it into an fgdb where you know the permissions are read/write.
Good luck,
Neil
