Calculate M-Values for Polyline
4051
06-09-2011 12:03 PM
GrantHopkins
Hi there!
I have a road network that includes M values. I want to ensure that all my roads have M values set as the distance/length. How can I set all the roads to have their M value equal their length?
I realize you can right click on a selected road and use the Route Measure Editing > Set As Distance... BUT I don't feel like doing that for hundreds of roads! I need a way to do this quickly to all the roads at once.
Thank you for any help!!
Grant
HardolphWasteneys
Grant,
LENGTH is the default option when you use the CREATE ROUTES tool.  Might be fastest to just recreate the routes and select that option.  A way of checking graphically might be to HATCH your routes and compare the end value hatch labels to the length.
Hardolph
GrantHopkins
Grant,
Hardolph
Hi Hardolph,
Thanks for your reply!! That's exactly what I need to do EXCEPT for the whole Coordinate Priority. Is there a way to use the accumulating lengths for each line but have them accumulate in the digitize direction? I need to keep my routes in a specific way (in increasing civic address direction), I'm trying to avoid having to go to each road and flip it if it's been changed due to the coordinate priority. I hope this makes sense.
Thanks!
Grant
HardolphWasteneys
Grant,
In that case you need to generate a FROM and a TO field for input using the TWO_FIELDS option under Measure Source.  Do this by adding the fields to your feature class and using field calculator to set the FROM field = 0 and the TO field =  Shape_Length .   That ought to respect digitizing direction in setting the M values of the created routes.
Hardolph
