Boundaries of my polygons are not matching perfectly
4177
01-14-2022 05:40 AM
Lloyd_Moyo
Hi everyone, I have five (5) polygons which are supposed to match. The problem is my polygon bounderies are not matching perfectly like indicated on the first picture . I want all my polygon bounderies to match perfectly or to have the same polyline kind of.
Thanks in advance
jcarlson
MVP Alum
There are a number of built-in geoprocessing tools you can use to accomplish this.
Or, since there are so few features, you can just use an editing tool:
  • Align Edge (requires enabling map topology in the edit tab of the ribbon; also won't work great unless the endpoints of shared edges are aligned first)
  • Align Features
- Josh Carlson
Kendall County GIS
Lloyd_Moyo
Lloyd_Moyo_0-1642167836141.pngLloyd_Moyo_1-1642167867256.pngLloyd_Moyo_2-1642167892533.png
Hi everyone, I have five (5) polygons which are supposed to match. The problem is my polygon boundaries are not matching perfectly like indicated on the first picture . I want all my polygon boundaries to match perfectly or to have the same polyline kind of.
Thanks in advance
DanPatterson
Moved to Data Manatement Questions
and consolidated your double post
... sort of retired...
jcarlson
MVP Alum
  • Align Features
- Josh Carlson
Kendall County GIS
