Attributtable change data type is not possible
701
02-22-2021 01:34 AM
A_n_d_r_e_a
Dear Community,
i want to change my data type for example into dates...but it is not possible because if i click on the properties there is no field tap. Why not? Ive got two standalone tables and a Feature Class in a File Geodatabase and i want to connect them but i need a different data type.
My Version 10.8.1
Thanks forward!
Greetings,
Andrea
2 Solutions
DanPatterson
You can't alter a field's properties once there is data in the table, you have to add a new field and calculate values in the new format from values in the old column.
... sort of retired...
A_n_d_r_e_a
Hey Dan,
you are always my salvation 🙂
Thats what i also try yesterday than it works, but i thought that there is maybe also an option in the properties because its written also here
https://desktop.arcgis.com/de/arcmap/10.3/manage-data/geodatabases/modifying-field-properties.htm
But thanks!
Greetings,
Andrea
DanPatterson
A_n_d_r_e_a
Hey Dan,
But thanks!
Greetings,
Andrea
DanPatterson
not sure if I saved you since you seem to have answered your own question 😉
