ArcGIS Desktop 10.0 SP3
Love the attribute transfer tool, except when it does not save my attribute mappings between ArcMap sessions. The unfortunate part is that the attribute mappings might save in a particular map document several times, but then it will stop saving the mappings so they need to be recreated each time the document is opened. Starting with a new document or different data does not help either. With potentially a large number of unique mappings (so auto-match does not help) this can be very time consuming.
Originally I thought this was due to broken data sources in the map document, but this does not appear to be the consistent reason for the attribute mappings to disappear.
Any others experiencing in consistent behaviour with the attribute transfer tool?
Thank you,
Sandra
