Attribute assistant help.
4283
14
04-18-2017 08:58 AM
elvissoto
I am new to Attribute Assistant tool, trying to learn to use in my company, can anyone help me how to set up value method & Value Info in dynamic table. I didn't find much documentation online.
MikeMillerGIS
Esri Frequent Contributor
If you are trying to intersect polygon to polygon, try to centroid option
https://solutions.arcgis.com/shared/help/attribute-assistant/documentation/methods-intersecting-features/#intersecting-feature
If you need more than one feature, that intersects, you something to use the concat method on intersect stats
https://solutions.arcgis.com/shared/help/attribute-assistant/documentation/methods-intersecting-features/#intersecting-statistics
We need to see the dynamic value table to see what you are trying to do. Why cant you turn on the debug log?
MikeMillerGIS
Set this to true to turn on the debug log
PintoJoão
Hello Michael Miller ,
Sorry for the Delay, a lot of work in the last few days and that´s why the AA will be the best help.
I already turn on de AA and attached the debug log.
My DynamicValue is that:
DynamicValue
Another Case:
Work
The blue polygon and blue Label number is the source, and i want transfer attributes to purple polygon.
I selected all rows and features at the same time and the result  was that you can see in the image.
The red line means the intersect features wrong.
One more time, I  want to thank you again for you great help.
João
MikeMillerGIS
You need to add the centroid flag. The intersection is correct without it, those polygons do intersect the other polygons on the border
PintoJoão
Michael, the intersection is correct without centroid flag?
My polygons intersect the other polygons on the border, but look the image and see the following example:
The first intersection of polygon 4552 is correct,but in the polygon below, the intersection did not seek information from  polygon 4555 and copied the information from the polygon above.
If add centroid flag, i can resolve this issue?
Sorry for another question, but how i add the centroid flag?
Thank you so much
