ArcMap won't open any other kind of file except .shp
4184
17
09-01-2016 05:44 PM
KaylaniMendez
New Contributor III
I'm trying to create a new level of data on my map but ArcMap will only recognize .shp files, how can I fix this? I already decompressed the entire .zip folder.
KaylaniMendez
New Contributor III
Thank you so much!
DanPatterson_Retired
Hope it worked out
NeilAyres
Patience of Job, Dan_Patterson
KaylaniMendez
New Contributor III
Yes it did! Thanks. I'm just really new at this, currently on an independent study course on this because nobody else signed up for the class. It's a nightmare
NeilAyres
Well after this, you can see what a nice bunch of people we GISsy types really are.....
I hope you continue your studies and get into GIS in a little more depth.
KaylaniMendez
New Contributor III
I hope so too! Thanks!
If you are with an educational organization, the person in charge should/might be able to get you access to a large number of esri training courses for free.  I know we do at our university and we make them available to all students.  They cover all levels of expertise and a huge number of areas of interest.  You should look into this possibility, otherwise look for free resources under Services and Support on the main banner.  Good luck
