ArcGIS - WGS 84 Transformation conflicts with other platforms
2366
05-08-2014 02:33 AM
SatishKumar3
I have rasters, need to be geo-referenced in WGS 84 datum with Lat/Log (degree). I have geo-referenced using Global Mapper, which we usually used to use, because of its user friendly. Got a vector data of the same raster through other sources, which also used GCS_WGS 84 (Could have been geo-referenced using ArcGIS with GCS_WGS84). When I overlap both the data, found off-set about 300 meters. Checked all data origins and geo-referencing, everything correct, still off-set unavoidable.
      To check further, I have geo-referenced same raster with GCS_WGS84 in Global Mapper and ArcGIS seperately. I found the same off-set of 300m.
Is that really different transformation applied in difference platforms, or any other parameters related to this??
MelitaKennedy
Esri Notable Contributor
Also asked on gis.stackexchange.com.
ArcGIS for Desktop with geographic/datum transformations is a late-binding system. We do not link a default transformation to a particular geographic coordinate system. When data needs to be transformed, then you set the transformation that you want used.
It's possible that Global Mapper is an early-binding system that sets a default transformation per geographic coordinate system.
Because of the size of the offset, I think no transformation occurred in ArcGIS.
Melita
GlennBrooks
I have a similar problem.
Using Global Mapper, I created a simple shapefile having 9 adjacent shapes laid out in a rectangle.  I used this layer to clip aerial imagery to the boundaries of each feature in the shapefile using Global mapper.  the clipped shapes are exactly coincident with the polygon edges.
When I import both the shapefile and cllipped images into ArcMap V10.2, the shapes and imagery become offset approximately 1.5 meters. Also, The latlong of a known point in the polygon/imagery overlap in ArcMap is hundreds of meters offset from the lat/long of the same point in Global mapper.
Also when I load the data in QGIS the layers are all conincident, only when I load into Arc10 are they not coincident.
In global Mapper the projections are:
shapefile:  WGS84 - lambert Conformal -Washington State Plane South -feet (US Survey)
Imagery:   WGS84 - Geographic ( lat/long) - Arc Degrees EPSG Code 4326 (obviously not Wash State Plane-South)
Problem 1:  How do I correct this overlap to achieve coincident data in ArcMap?
Problem 2:  In Arcmap I went into Catalog image file/properties and changed the image projection to State Plane South - the image file then disappeared from the screen and would not display.  reset the original projection and it re appeared.
Thanks
Glenn
