ArcGIS import workspace document error, cannot create a table with duplicate column
6127
01-21-2015 04:47 AM
FaheemRehman
Hi All,
I have a XML workspace document of a geodatabase version 9.2. When i import it into new File geodatabase version 10.2 it gives me this error
Cannot create a table with duplicate column. Your help is appreciated
FalconESRIKW
This could be the case of client and database incompatibility.  It would be worth a try to import this XML into 9.3  file geodatabase first. If it imports successfully then create a new XML from 9.3 geodatabase and then import that into 10.2 file geodatabase. ( you can also copy-paste the data from 9.3 geodatabase to 10.2 geodatabase)
You can create 9.3 file geodatabase using Create Filegeodatabase tool:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Hope this helps!
