ArcGIS 10.4 export to pdf - bad result at certain scale
502
12
01-16-2018 12:25 AM
GuidoScheers
New Contributor II
Export to pdf gives a bad result at certain scales for arc shaped polygons. Idem with PDF Creator, export to png, using arcpy, ...
See images below: purple arc is properly exported at 1:40.000, but not at 1:20.000
Features are stored in arcsde geodatabases.
Has anyone an idea what the problem is?
If the arcsde polygon feature class is saved as a shapefile, the shp polygon is properly exported to pdf, but... no, I won't save all feature classes to shapefile as a workaround.
Thx, Guido
DanPatterson_Retired
MVP Esteemed Contributor
looks like a precision issue with the sde dataset.  can you upgrade it?
GuidoScheers
New Contributor II
Hi Dan
What do you mean exactly with "upgrading the sde dataset"? At feature class level?
In the feature class properties window on the General tab under Geometry Properties is indicated: "Storage: High Precision using Esri Binary spatial type". Anything to do with that?
Or do you mean upgrade at geodatabase level?
Guido
When you said it was fine as a shapefile, it just sent off a trigger that IF a coordinate system is defined, shapefiles use high precision.  Shapefiles also don't use arcs as a native format, they are converted and would not exhibit the behaviour you have shown when scaled.  That leaves the lack of a coordinate system or something else influencing whether high precision is used (you have ruled that out) or the precision at which the coordinates are collected and locations are treated as being equal.  Your offset of the endpoints doesn't seem to fit into that category.  Leaving the location/delivery of the data.  If exported to a featureclass to standalone, locally stored geodatabase, I wonder if the behaviour you have demonstrated still exists.
GuidoScheers
New Contributor II
Copy in locally stored file geodatabase doesn't make any difference.
But.. trying things out, I'll blame the map document itself. I noticed following strange behavior: visible transparent layers in the Table of Contents above this feature layer cause a bad pdf export result.
So I'll rebuild the map document from scratch (I admit I built the original map document by drag feature layers from other mxds). Until then this topic can be closed.
Thx.
You can mark any question as providing the answer or was helpful Guido, otherwise, you can mark it Assumed Answered or convert it to a discussion.
Good luck
Asrujit_SenGupta
MVP Regular Contributor
Create a copy of the Feature Class in the same geodatabase, but using the GEOMETRY storage type and check...does that make any difference?
GuidoScheers
New Contributor II
Sorry, doesn't make any difference.
RebeccaStrauch__GISP
Occasionally, in the past, we will get a bad results with no real explanation.  It may be something that could re fixed using the Checking and repairing geometries—Help | ArcGIS Desktop    But sometimes we just need to move the extent....very little so it doesn't affect the map...and it will work.  Might not work in your situation, but never hurts to try.
MichaelVolz
Might this issue be associated with this other export to pdf bug:
https://community.esri.com/thread/203744-pdf-export-character-spacing-1051-issue
Not sure if you have access to 10.6 prerelease to see if this issue has been fixed there.  If this has been fixed in 10.6 like the character spacing issue, it would be nice to get a patch for 10.5.1 as upgrades require a much longer timeframe and much more extensive user acceptance testing.
