ArcGIS 10.1: Starting ???ArcSDE Service (esri_sde)" stops!
3920
21
12-14-2012 11:08 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Starting �??ArcSDE Service (esri_sde)" stops!
I tried to start the �??ArcSDE Service (esri_sde) service but I got the messages below:
[ATTACH=CONFIG]19951[/ATTACH], [ATTACH=CONFIG]19952[/ATTACH]
What might be the problem?
Thank you in advance
Best
Jamal
by Anonymous User
Not applicable
Original User: vangelo
That's a standard Windows error that appears whenever the ArcSDE service has been
misconfigured in any way.  Unfortunately, you didn't provide any of the information which
would be necessary to help you:
RDBMS product, version, and service pack/patchset
ArcSDE version, service pack, and any additional patches
The output from 'sdeservice -o list'
The contents of your SDEHOME/etc/dbinit.sde file
Any error messages from the SDEHOME/etc/giomgr.log
An architecture description (the OS type and relative location of the ArcGIS Server,
ArcSDE, and database components)
All in text form, not as graphics, please -- It's important to place error messages in the
message text block, because that's how others would be able to find your solution.
In fact, if you had searched on the key words of the message ("arcsde service started
then stopped"), you would have found a number of useful postings.
- V
JamalNUMAN
Legendary Contributor
- V
Thank you for the answer Vince.
Please, find attached the steps (powered by screenshots) that show how I configured the application server. I�??m sorry not to provide these steps in text format as I wanted to let the screenshots to speak out themselves.
�?� I�??m using Windows 7 64 ultimate, sqlserver 2088, ArcGIS 10.1 (advanced), ArcSDE 10.1 (Enterprise)
�?� sqlserver 2088, ArcGIS 10.1, ArcSDE 10.1 are installed on the same machine named m-pc
�?� The dbinit.sde file contains nothing
�?� The ArcSDE is installed in
C:\Program Files\ArcGIS\ArcSDE
�?� The sql server database is physically saved in
C:\Program Files\Microsoft SQL Server\MSSQL10.MSSQLSERVER\MSSQL\DATA
Hope that this is sufficient to lead me to my problem and thus I can get the service started.
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: mboeringa2010
Don't know if this is the issue (I don't have ArcSDE at hand right now), but I did notice that in the screenshot of the windows "services" file in notepad, that you copied the
"esri_sde 5151/TCP"
line at the end of the text file.
If I remember it well, the line needs to be inserted in the rising order of port numbers, so in your case in between two other port number entries of the file.
JamalNUMAN
"esri_sde 5151/TCP"
Thank you for the answer Marco
the �??esri_sde               5151/tcp�?� is copied onto srvices file in page number 52 in the attached pdf file and also shown in the screenshot below:
[ATTACH=CONFIG]19964[/ATTACH]
if the place of �??esri_sde               5151/tcp�?� in the service file is an issue then where should it be positioned?
Jamal Numan
by Anonymous User
Not applicable
In the rising order based on port number, so in between
ipsec-msft 4500/udp
and
llmnr 5355/tcp
I would also refrain from using empty lines in the services text file.
Marco
VinceAngelo
Esri Esteemed Contributor
Marco -
While it is probably wise to populate the services file in port order, it certainly isn't required.
The only thing that's necessary is a terminal newline (otherwise the last line in the file is
discarded).  Empty lines are legal (and ignored, just like lines with leading octothorpes).
- V
by Anonymous User
Not applicable
ipsec-msft 4500/udp
and
llmnr 5355/tcp
Marco
Thank you for the prompt answer Macro.
I tried it but sounds not to work. Please, have a look on the screenshot below
[ATTACH=CONFIG]19975[/ATTACH]
(Of course I saved the file after the change)
What other suggestions might be helpful?
JamalNUMAN
Marco -
- V
Hi Vince,
Thank you for the answer.
Could you please elaborate more regarding the �??terminal newline�?�?
What should it contain?
[ATTACH=CONFIG]19976[/ATTACH]
Jamal Numan
by Anonymous User
Not applicable
Marco -
- V
Hi guys,
An instructor provided me the answer! What follows the �??p should be sde123 but not sde
[ATTACH=CONFIG]19986[/ATTACH], [ATTACH=CONFIG]19987[/ATTACH], [ATTACH=CONFIG]19988[/ATTACH], [ATTACH=CONFIG]19989[/ATTACH][ATTACH=CONFIG]19989[/ATTACH]
Best
Jamal
