ArcGIS 10.1 SDE services not starting
7376
12
11-21-2012 05:41 PM
appsapps
Getting problem while starting Arcgis Sde services.
Error starting esri_sded service(1053)
Could not start ArcSDE -- Check Network, $SDEHOME disk, DBMS settings and dbinit
.sde.
Help needed.
Thanks in advance.
LuisinaArrúa
Hi all:
I have a problem with arcSDE:
A)Development Workstation
Windows 2008 server Enterprise 64-bit
ArcGIS Server for Enterprise 10.1
ArcSDE 10.1 for Oracle10g
Oracle Client: 10.2.0.4
B)Database Server:  (Separate server)
windows 2003 server and  Oracle Database 10g Enterprise Edition Release 10.2.0.4.0
C) Sdeservice list
C:\>sdeservice -o list
SDE service Information
RDBMS:              Oracle
Name:                 ArcSde Service(esri_sded)
SDEHOME: C:\Program Files\ArcGIS\ArcSDE\ora10gexe\
Version:              10.1
Status:                 SERVICE_STOPPED
What's the problem?? please help !
don't start the service SDE!
thanks!
VinceAngelo
Esri Esteemed Contributor
Instead of adding to a 3-year old post, it would be better if you created a new post, referencing the other one as necessary.
It's been a long time since I responded to an application server install question, but the root cause is probably the same -- failure to use LOCAL (or TWO_TASK on Linux) as a variable instead of ORACLE_SID in the dbinit.sde file (as documented in the install instructions).
I have to recommend that you abandon Oracle 10gR2 and adopt 11gR2 as the minimum database release.  ArcGIS 10.4 and beyond doesn't/won't support Oracle 10g or 11gR1 or even 11gR2 below 11.2.0.4.
- V
User35489
As Vince wrote, Double check DBINIT vairables
set SDEHOME=
set ORACLE_SID=
set SDEVERBOSE=TRUE
setenv TNS_ADMIN
setenv TWO_TASK
