string pathName = Directory.GetCurrentDirectory();
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Engine);
//// Force ESRI to pick up the new Spatial reference from the .prj file
ISpatialReferenceFactory pSpatialReferenceFactory = new SpatialReferenceEnvironmentClass();
ISpatialReference pSpatialReference = pSpatialReferenceFactory.CreateESRISpatialReferenceFromPRJFile(prjFileName);
// open the directory as a worekspace
Type factoryType = Type.GetTypeFromProgID("esriDataSourcesRaster.RasterWorkspaceFactory");
IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);
IWorkspace workspace = workspaceFactory.OpenFromFile(pathName, 0);
IRasterWorkspace rasterWorkspace = (IRasterWorkspace)workspace;
// open the raster file
IRasterDataset r = (IRasterDataset)rasterWorkspace.OpenRasterDataset(tifFileName);
r.BasicOpenFromFile(tifFileName); // not sure if this line is needed
IGeoDataset igs = r as IGeoDataset;
IGeoDatasetSchemaEdit2 gds = r as IGeoDatasetSchemaEdit2;
gds.AlterSpatialReference( pSpatialReference) ;
igs.SpatialReference.Changed(); // tell it that we have changed the rasters's spatial reference
// Open the Raster & change its SpartialReference
RasterDatasetClass r = new RasterDatasetClass();
r.AlterSpatialReference(pSpatialReference);
Hi Bill, were you able to resolve your issue? We have similar 9.3 code that is throwing an AccessViolationException in 10.2.2. So I was wondering if you were able to find a fix for 10.x Thank you!
