Address Locator Error Message
9679
36
02-06-2014 07:33 AM
GuyKouwoaye
I was trying to geocode an excel table in which I have Zip code and Address as some of its attributes. I chose " US Streets Geocode Service Online(ArcGIS Online) Locator and got this error message: " The address locator is damaged. Resource is not available, regardless of authorization".
Can you tell me what I have to do to fix this problem?
JackBeers_III
@jthyen: You may need to call Esri support if you don't see it. The service shows up on my end as 'World'.
[ATTACH=CONFIG]31899[/ATTACH]
I also found this video that might help:
" rel="nofollow" target="_blank">http://www.youtube.com/watch?v=HW-1utzu4nI[/video]
Good Luck,
PatMoore
PMoore:  Can you please post that XML file that Kara from ESRI provided you?  I've tried the steps in the link you provided, per the suggestion of another post-er, but that didn't work for me.  I'd like to try what Kara offered you.  Thank you.
Actually, I've done everything in the instructions-including the XML file and although I can get to the new World Address Locator-it still doesn't work and so far no one has been enable to tell me why...I have ESRI people working on it now and will let everyone know what happens
AnthonyHedberg
ESRI Geocoding Workaround
ESRI has moved all Online Geocoders to their new credit system. Still available are their StreetMap_NA geocoders that are provided with software.
-When Choosing your Address Locator -> ESRI Data Folder -> streetmap_na -> data -> Desired Address Locator
View Image
[ATTACH=CONFIG]31958[/ATTACH]
CFrate
So if you hypothetically started with 1,000 credits and you only geocode to use credits, you could geocode 25,000 records.
This was what I had originally understood, but Esri support explained otherwise (the 1000 credits to geocode 40 records was straight from Esri support... Not that getting a dozen totally different responses from a dozen different techs is anything new).
I'm still testing alternatives, because we have no immediate plans (or money) for purchasing credits.
PatMoore
I know what you mean-we have the credits but the World Address Locator still doesn't work!
PatMoore
I know what you mean-although we have plenty of credits, the new World Address Locator never has worked for us and no one seems to know why!
CharlieDuncan
I just got this problem fixed.  I have 10.1, and was able to get a trial subscription that comes with 200 credits: enough for 5000 geocoding matches (someone had it backwards when they said 1000 credits for 40 matches--not true, but the opposite).
The customer service rep provided me with an .xml and some instructions.  Go through the rather simple process and get to geocoding again...at least for a while.
