10.2.2: TIFFs are not lining up using control points
2951
11-12-2015 07:38 AM
AmyFrederiksen
I work in a county real property office, mapping and maintaining parcel info. All of our filed survey/subdivision maps are converted to TIFF files, and work flow requires us to bring them into an ArcMap session on a regular basis. In earlier versions of ArcMap, we were able to use control points and they would neatly lie where we asked them to. Not so in 10.2.2. After dropping a few control points, the image shifts off of those points.
We can bring the map in by other means(using "fit to display", rotate and using a scale factor), but the control point method seemed to save a lot of time for certain applications... any ideas out there?
