It would be a lot simpler if when replicating hundreds of sde tables (not feature classes) I did not have to change from Schema Only to All Records on each individual table I am replicating. If that is not feasable or palatable, at least give the creator of the replica the chance to change all of the tables at once from Schema Only to All Records (or vice-versa).
