Use All Records by Default instead of Schema Only for Replication of SDE Tables
858
04-26-2011 11:32 AM
Status: Open
AaronLankford2
It would be a lot simpler if when replicating hundreds of sde tables (not feature classes) I did not have to change from Schema Only to All Records on each individual table I am replicating.  If that is not feasable or palatable, at least give the creator of the replica the chance to change all of the tables at once from Schema Only to All Records (or vice-versa).
