Registering views as editable would make every single day easier
204
05-28-2020 01:30 PM
Status: Open
AdamStewart
New Contributor II
Not every attribute is representative of a primary key, obviously.  Especially when you have delta T (current) records.  No sane database design is going to have all attributes in a single table.  This is 40 year old design methodology.  The right way to have a primary key (item) and single source of truth is to leverage relations, often through views with INSERT/UPDATE triggers.  Not being able to register a view as editable is a bad design decision that has nothing to do with whether the views are *actually* "editable."
There is so, so much custom coding and ETL work that needs to be done to get around that frustrating limitation.
