Geodatabase Questions
156
13.7M
1.9K
NOTE: Data Management ideas require a single label. See the descriptions to choose the label that best aligns with your idea submission.
Open | When migrating data from a source feature class to a destination feature class (new or existing), I found an issue if... by GKing New Contributor II 1 2 | 1 | 2 | |
Closed | I am in a situation to migrate huge database that contain more than 6 million records with tens of feature datasets ... by MarGIS New Contributor III 0 6 | 0 | 6 | |
Open | One behavior of Table To Table—Conversion toolbox | ArcGIS Desktop, Copy Rows—Data Management toolbox | ArcGIS Deskto... by JoshuaBixby MVP Esteemed Contributor 0 3 | 0 | 3 | |
Closed | In ArcMap there is the Load Objects Command, it's found under customize mode. See link on how to add it in ArcMap. I ... by RichardLittlefield Occasional Contributor II 20 15 | 20 | 15 | |
Open | I recently ran into the following problem:Problem: Data type in a feature class converts to double when exported from... by ColleenFarrell New Contributor III 0 0 | 0 | 0 | |
Open | When using the data loader in ArcCatalog. You spend the time to map out the fields to load into which field. Then af... by RobertBorchert Frequent Contributor III 10 2 | 10 | 2 | |
Open | When copying a layer in arcatalog, an option could purpose to keep or reinit the objectid field of the copying featur... by DelaereMickael Occasional Contributor II 7 2 | 7 | 2 | |
Closed | Can we please have the ability to export symbology with a feature class / Layer when exporting it to a geodatabase. T... by JasonKennedy New Contributor III 7 3 | 7 | 3 | |
Open | sdeexport/sdeimport command is very fast and stable.ArcSDE command will be retired and ArcGIS can't handle the format... by SatoruGunji1 New Contributor II 6 0 | 6 | 0 | |
Already Offered | Currently it seems that once can use "cut & paste" to quickly move gemoetry from one shapefile / feature class to ano... by SeanGambrel Occasional Contributor II 6 6 | 6 | 6 | |
Open | We have data that gets extracted from other sources and a filegeodatabase is created nightly. We need to load this da... by DorothyMortenson Occasional Contributor II 25 1 | 25 | 1 | |
Open | There is a 'silent' datum transformation that may (or may not) take place when data is imported (Feature Class to Fea... by TylerGrosshuesch New Contributor II 4 0 | 4 | 0 | |
Already Offered | The file geodatabase API/SDK should support any coordinate system ArcGIS itself understands and can use.After days of... by mattwilkie Occasional Contributor III 36 5 | 36 | 5 | |
Open | When merging files some fields may have different data length values. This results in an error and the file process ... by jimhansen New Contributor II 8 1 | 8 | 1 | |
Open | It appears that you can connect to a PLS-CADD database via any ODBC connection. How you get the data out of PLS-CADD... by Anonymous User Not applicable 5 1 | 5 | 1 |
Idea Submission Guidelines
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
