Hosted Feature Layer copy to ArcGIS Server as a back-up data option
1554
06-03-2021 01:14 PM
Status: Needs Clarification
LisaDygert
Since Esri does not currently provide a data back-up option for hosted feature layers, there should be a way to easily export a hosted feature layer as a feature layer on a local ArcGIS web server.  That way, the data can be backed-up in a sense.  With this....there should be ways to  maintain the original globalid values so that relates are not lost.
5 Comments
JayantaPoddar
Hosted layers are stored in ArcGIS Data Store. Does Managing Data Store Backups work for you (in case the hosted feature layers are in Portal for ArcGIS)?
LisaDygert
I am referring to the hosted feature layers that get creates from Survey123 forms which are not stored in portal. I don't believe the document you sent includes that situation, correct?
DerekLaw
Hi @LisaDygert,
> Since Esri does not currently provide a data back-up option for hosted feature layers ...
Please review these 2 items:
Hope this helps,
KevinMacLeodCAI
The apps from GeoJobe look very useful https://geo-jobe.com/backupmyorg/
SSWoodward
Good Afternoon @LisaDygert ,
We know its been a while, but wanted to check to see if any of the documents provided by @DerekLaw helped you find a solution to your back-up needs.
Let us know here in the comments if you have a moment. Thanks!
