Enhance date fields in feature services to support millisecond
900
10-15-2020 11:59 PM
Status: Closed
MateuszŻak
New Contributor II
Enhance date fields in feature services to support millisecond resolution when adding, editing, or querying features.
We have feature service which writes date to MS SQL database, even thouth we have datetime2(7) data type fields, feature service writes only seconds. For example - when you try use aply edits operation and put 1543479941234  value to the datetime field, it will be cut to seconds, when you try to force service to write miliseconds (trying "DateTimeField" : "2020-10-06 11:11:11.34" ) it will bee decline by the server.
It is imposible to use ESRI Feature Service to work with highly accurate time data.
1 Comment
SSWoodward
Status changed to: Closed
This idea has been closed as it is a duplicate of an idea on the Enterprise Geodatabase Ideas Exchange.  If you'd like to show it some support, follow the link below to the active idea and give it a thumbs up there!
https://community.esri.com/t5/arcgis-enterprise-ideas/enhance-date-fields-in-feature-services-to-sup...
