DBO Schema support for Branch Versioning
1155
03-23-2021 03:25 PM
Status: Needs Clarification
LukeSavage
Occasional Contributor II
Please add branch versioning support for DBO Schemas.
2 Comments
MelissaJarman
What specifically are you trying to do that is being blocked for datasets stored in a SQL Server DBO schema geodatabase? Are you trying to register as branch versioned?
LukeSavage
I should be able to create a version within the database as well as the service.  Also, UN should be able to follow the security protocols of a DBO schema and if you are the DBO.  Right now, you need a user schema for the UN.  Pre-ArcGIS 9.2 tech.
