Dashboard Category Selector filter options don't update when changing between String and Integer.
222
07-08-2020 09:48 PM
TysonM
New Contributor III
I have a layer with string and numeric data (decimal).
I add a slider with Defined Values and use Integer Values (it defaults to String).
I add an integer value.
I go to Actions and select the layer and filter. My only options are String fields.
I have to Save my Selector, only partially setup.
I edit the Selector and the filter options now offer the numeric fields.
Changing the Defined Values option between String and Integer should update the fields that can be filtered.
JohnSolly4
Good find Tyson TM
This has been fixed on our most recent development build and will be resolved when the beta is released again (Date TBD)
- John
