Help with COVID-19 stats counters
735
04-03-2020 10:02 AM
Rigoberto_Sanchez
Hello,
I am manually updating COVID stats in my AGOL Dashboard each day. I created them by using the Rich Text element. I am seeing that many dashboards out there have their stats automatically updating.
I have attempted to use the Embedded Content element but each time I use a URL it brings in the whole webpage. I am thinking that if I can get access to the specific URL for each counter perhaps the Embedded Content element can work.
Any tips or references to other posts about how I can automate this process will be greatly appreciated. Please note, I am fairly new at using Dashboards and I am strictly working off of AGOL. Also, I don't have access to an ArcGIS Server.
Here is an example of my current work.
example of covid stats counters
Here is a link to the counter I would like to replicate its display of stats.
https://lacounty.maps.arcgis.com/apps/opsdashboard/index.html?utm_content=&utm_medium=email&utm_name...
Thanks!
Tags (3)
JuanMorteo
New Contributor II
Are you using a service from a authoritative source?  John Hopkins University (JHU) shared their data to the public and can be easily added to your map in Portal/AGOL.  I am using this link, just copy the service URL and add it to your map (https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases_US/FeatureServer ).
They are updating their data frequently, which eliminates any manual updating on your end.  I created a Dashboard for my organization using their service and displaying the data using a List element or you can use an Indicator element.  Hope this helps.
JuanMorteo
New Contributor II
Rigoberto_Sanchez
Hello Juan,
Thank you for the prompt response. I followed your guidance and I was able to make it work. I ended up opting for the Indicator element. Many thanks!!!
Here is an example of the outcome.
final covid counter
Just in case anyone sees this post in the future...if you don't know how to add a Feature Service/Service URL, they look like this,
service directory
you can use this helpful guide: https://communityhub.esriuk.com/technicalsupport/2014/7/22/how-to-use-arcgis-server-services-in-arcg...
JuanMorteo
New Contributor II
Glad you were able to make it work, that’s why we are here to help each other out.
