Living Atlas team,
We are using the JHU's feature layers to feed our COVID web map. Could you please enable time settings? We want to test a time animation or a time slider (widget). Also, we are interested in using a field of "Active Cases" as an indicator or list. Is there any reason why "active" stats are not available in the attribute table? Or, can you share a way to bring "active cases" to the indicator or list panel?"
TC Chakraborty and Miriam Olivares
Solved! Go to Solution.
I am a user of their layers as well. But I don't know if/when they plant to offer a time series version of the data. This mentions why active cases are an attribute in some layers but not populated for all areas. See the FAQ or contact Johns Hopkins for more information.
