X-Y Data disappears when added to map
4452
14
12-09-2014 03:08 PM
LauraMiller
Hi, I'm having trouble adding X-Y data to my map.  I exported data that shows perfectly to geocode some points that ArcGIS didn't geocode; when I pull the data back in and add it to the map it does not show with the rest of my data.  Is there some parameter that I am missing?  Has anyone else had this issue?
ChadKopplin
Laura,
Would you mind sending the file in order to take a look at the points?  Thank you in advance.
Chad
LauraMiller
Can I post a file here?  I would have to cut it down substantially - I don't want you guys to bother with a 70,000 record file - but I will pare it down to about 20 points and post, if I can.
ChadKopplin
Yeah just post 20 records that do not show, it has the feel of a wrong coordinate system, but just wanted to check.  Where should the points be located?  Thank you.
LauraMiller
North America.  The rest of the map is using GCS_North_American_1983.  I'm trying again making sure to use that, and BINGO! it worked.  Evidently the first time it matched the coordinate system of open street map and got very confused.  Thank you all for your help!
LauraMiller
Thanks to all that replied - the problem was that the coordinate system was not specified correctly when adding the X-Y data.  I deleted the layer and added again, making sure to match the coordinate system of the other layers, and the data showed up perfectly.
