coordinatesystem-strings - parameter in prj-files
3687
10-29-2014 04:50 AM
MarkoEinspieler1
Dear all,
I'm using pyhton to read out prj-files. In some strings I found after the paramter [UNIT] some values and I do not really know for what they are needed? Here is a string expamle:
Have anyone an idea? Are these some kind of transformation parameters?
Thank you and with best regards,
Marko
SachinKanaujia
Occasional Contributor III
If I recollect it correctly then those are XY domain, Tolerance, Precision related values. They are not used for transformation
MelitaKennedy
Esri Notable Contributor
Sachin Kanaujia‌ is correct. They are used in geoprocessing to fully store or create a spatial reference, but a regular 'prj' or coordinate system string doesn't include these values. They are, in order:
minimum x value
minimum y value
xy precision (1/precision = xy resolution)
minimum z value
z precision
minimum measure value
m precision
xy tolerance
z tolerance
measure tolerance
IsHighPrecision: marker that the spatial reference is high precision, rather than the older standard precision.
Melita
SachinKanaujia
Thanks Melita Kennedy. My UpVote for the elaborate answer and also refreshing my memory
MarkoEinspieler1
I hook up with Sachin Kanaujia‌. Thanks to you and Sachin Kanaujia‌ for the fast answer!
Marko
