Coordinate Reference Systems Questions
Search instead for
Latest Activity
Sort by:
POST
Hello!I'm trying to map point from survey plats that are using a state plane coordinate system with 1983 datum with 1...
0 0
POST
We are looking into more low cost GNSS rover devices which unfortunately only measure ellipsoidal heights. To use tho...
EkremCanli1
by EkremCanli1 New Contributor III
1 1
POST
Hello all,I have a question about scale tool of the georeference box.What type of value can I add in the in the adjac...
0 0
POST
I have been provided it a shapefile from MapInfo. When I bring the shapefile into ArcGIS Pro 2.5 the polygons are c.5...
SarahMoore2
by SarahMoore2 New Contributor
0 0
POST
I have a shapefile in ITM and I brought it into ARCGIS. In ARCGIS Pro some of the layers are in ITM and ome are Irish...
SarahMoore2
0 5
46
POST
Hello,I have been learning Transformation concepts working with matrix algebra to develop a basic 2d conformal transf...
ChuckTurlington
by ChuckTurlington Occasional Contributor II
0 1
POST
Hi,i am working with various layers that have the following coordinate system and projection:Coordinate system: GCS_C...
MartaBescansa1
by MartaBescansa1 New Contributor II
0 4
POST
I recently came across a problem where I had created a number of polygons from existing lines using the "Construct Po...
MatthewMassey
by MatthewMassey New Contributor II
0 0
POST
Are there any tools out there that can read a *.gtf file and convert it into a shareable format for non-ArcGIS users ...
NeilAyres
by NeilAyres MVP Frequent Contributor MVP Frequent Contributor
0 1
POST
Apologies in advance if this is a dumb question or I'm missing something obvious... It's rare I have to leave the con...
0 4
