Coordinate conversions from NAD 1927 to WGS84
3565
08-13-2014 10:29 AM
DaniellePhelps
Hello,
I am in need of converting a few coordinate points from NAD 1927 into WGS84. I have the ArcGIS Student (10.2) edition and have tried to find how the Projection toolbox and it says that it is not supported. Do I need to use the full ArcGIS version? Or should I try and use the NADCON method of converting?
Thanks.
IanMurray
Honored Contributor
Are you sure you are using Project (Data Management) not Project(Coverage)?  Project (Data Management) is in the Data Management > Projections and Transformations Toolset and should be available for basic licenses.
IanMurray
Honored Contributor
