Limit entries in dynamic text when multiple items are in the view extent
763
11-06-2024 11:27 AM
James_N
HI
I am using dynamic text to show information regarding points that appear in the view extent of my map in a map series.  The problem is that is there are multiple points in the view extent, the dynamic text boxes display the information for all of the data.
Is there a way to get Arc Pro to only put the information for a particular item in the dynamic text boxes?
To create the map series, I created a series of polygons.  There is a column in the polygon with the ID of the point it is centered on.  I was thinking I might be able to use that to select which information I want the dynamic text boxes to show, but I haven't found any relevant articles.
I am using Arc Pro 3.2.0
Thanks for any help.
James_N
It appears I have solved the visibility issue with a page query.  I think I was trying to find the hard way to do it and didn't think about the easy way.
