Indicate if we already gave an idea a thumbs up kudos
473
8
01-15-2021 01:11 PM
MarkVolz
When viewing all of the ideas it may be useful if the kudos icon changed colors if we had already voted up the idea.
Thanks!
KoryKramer
Community Moderator
Thanks for the suggestion, Mark!  Since it isn't related to an improvement in ArcGIS Pro, and rather is feedback about the Esri Community site in general, I moved it out of the ArcGIS Pro idea exchange.
When you say "when viewing all of the ideas" I'm assuming you're referring to the Latest Activity feed on an ideas board.  Is that correct?
For example, https://community.esri.com/t5/arcgis-pro-ideas/idb-p/arcgis-pro-ideas
below you'd like to be able to quickly tell if one of those two votes was already from you.
DanPatterson
MVP Honored Contributor
... sort of retired...
KoryKramer
Community Moderator
Thanks, Dan 😀.  Yeah, as I thought through the suggestion, I also realized that when you're looking at an individual post, you can tell whether you kudoed or not.  But I see Mark's point about being able to quickly determine that when scrolling through the activity feed.
Katherine_Clark
MVP Regular Contributor
Hello all,
I had a somewhat related question - does the number of kudos affect the visibility of the Idea in the same way the "thumbs up" did in the old Geonet?
KoryKramer
Community Moderator
Hi Katherine, can you clarify what you mean by "affect the visibility"?  Are you asking if giving a kudo moves an idea up in the Recently Updated view of the Latest Activity feed?
Comments (including Status Change, which adds a comment) along with other edits will count as recent activity.  Adding or removing a kudo does not count as recent activity.
Is that what you are asking?
Cheers,
Kory
Katherine_Clark
I'm referring to how in the old Geonet, Ideas that received enough "thumbs up" were more likely to be considered and added to the product plan. How is that handled in the new system?
KoryKramer
Community Moderator
Katherine_Clark
Yes, thanks so much Kory! I appreciate the help. I'm still getting used to finding my way around this place 🙂
