I might be losing my mind, but I can't find anyway to get to draft content.
If I start a blog and save it as a draft... where is it? How do I get access to it?
Brian Baldwin, Esri Inc., Lead Solution EngineerSolved! Go to Solution.
Hi Brian, Go to the place's blog board where you created the blog, and you will see a Blog Dashboard in the bottom right column where drafts are saved.
You will see a (1) in the parenthesis for View All Drafts in the place you saved your blog.
Hi @Anonymous User , it would be great if this information were added to your Help blog post about how to write a blog. Unless a blog is pretty short, I think most people would save a draft before publishing.
Hi Laura, The doc is now updated. Thanks!
Thanks! This often happens to me as well... "where are my drafts"??? Joseph Kerski
Awesome! So, I'm not losing my mind - thanks @Anonymous User. While I am glad it exists, I think it would be great to have any blogs/drafts/etc. roll up to a central place where users could locate them more easily.
Brian Baldwin, Esri Inc., Lead Solution EngineerGreetings, Brian. If you go to the blog board where you created the blog,you will see a Blog Dashboard in the bottom right column where you can save drafts. Check your Google Search Console.
