AWS Elastic IP change from one IP address to another.  How to fix broken service?
4261
09-17-2014 09:55 AM
PeterVaziri
New Contributor II
Recently an established elastic IP address was dropped and a new one was added and binded to the EC2 instance (e.g., 54.1.1.1 is now 54.2.2.2).  As a result, an ArcGIS service won't start up giving the error message:
SITEHOST
null
How did SITEHOST become null?
This service is accessing an SDE instance running on the same machine.  Other services start up find (file geodatabase-based).
Is there any kind of config file that can be updated with the new address information without republishing from an ArcMap?
Even worse, will republishing fail?
Pete
