What are "Map Notes?"
4728
08-19-2015 02:16 PM
Yavapai-ApacheNation
I'm confused when adding content to my "Story Map Tour" or Story Map Journal.  Are "Map Notes" the same as adding a layer and placing points on it? Also, when configuring the map for a Journal section, It just has a checkmark for "Map Notes" but does not let you differentiate between different sets of them.
GregoryL_Azou
Occasional Contributor III
Map notes are a type of layer that you can add to a web map through Map Viewer. It's helpful if you want to add couple of annotation. More information in the documentation at Map notes—ArcGIS Online Help | ArcGIS
If you add multiple layer you should be able to toggle them on and off in Map Journal
In Map Viewer
In Map Journal
GregoryL_Azou
In Map Viewer
In Map Journal
Thanks for your reply. Fast! I will study the links too.
Judie Piner
Preservation & Technology
Yavapai-Apache Nation
When in the map viewer, how do I add additional points to a map note at a later time?
GregoryL_Azou
You must have an edit button in the toolbar or use the option on the layer and click "Edit Layer"
