Story Map Journal file limit.
4093
04-23-2015 03:01 PM
JanieGoddard
When I created a Story Map Tour there was a 99 record limit for the point file. Is there a 99 record limit for the point file into the Story Map Journal?
Janie
GregoryL_Azou
Yes Map Journal also has a limit set by default to 101 sections (home section + 100 sections).
All of our apps have that kind of restrictions, for Map Series it is set to 15.
If you want to customize that, see this FAQ for Map Tour, the same pattern can be applied for Journal and Series.
GregoryL_Azou
JanieGoddard
Hi Gregory,
   Thank you so much for getting right back to me. We will keep these limits in mind as we design our Story Map Journal. We are building some curriculum along the Trail of Tears. This application is the perfect fit for our Tour.
    I made a Web Map Tour for a high level view of the Trail of Tears.
Thanks again,
Janie Godard
GregoryL_Azou
Great, you are welcome, happy story mapping!
