Shortlist Popup
459
14
08-23-2017 04:22 PM
RickeyFight
MVP Regular Contributor
I am getting weird functionality when using the latest version of the shortlist story map.
Here is a demo of my site.
http://gis.ashland.or.us/cipstoryshortlist/
If you zoom into a feature and click on the polygon a popup will appear (as expected).
But if you click on any item in the tab the popup will not display anymore when clicking on the polygon.
I am not sure what is causing this and I do not see any errors in the log that pertain to this issue.
Any help would be appreciated.
Reply
MarkCooney
Occasional Contributor III
Hi Rickey,
Try removing the polygon layer, and add it as an individual Feature Layer in the web map viewer (Add > Add layer from web > Layer: CIP Project Overviews (ID: 1) > Add layer.  The popups should then work as expected with that layer.
Mark
Reply
MarkCooney
Hi Rickey,
Mark
Reply
RickeyFight
I just tried this as a FeatureServer layer and MapServer layer and neither changes the end result.
Reply
MarkCooney
Strange, it works on the hosted version: http://ashlandgis.maps.arcgis.com/apps/Shortlist/index.html?appid=84af55e15dd942f39e8bbc9aa648edd6 (which is version 2.3.2).  I tested version 2.3.3. as well without issue.
Reply
RickeyFight
Yes the hosted one works for me but not the downloaded version. I have tried with different shortlist app id and it still gives me the same results.
Did you get the same results when looking at my webapp?
Reply
MarkCooney
Correct, I can repro the popup issue you describe with your custom shortlist app.  Do you see the same issue here?  http://storymaps.esri.com/templates/shortlist-2.3.3/?appid=84af55e15dd942f39e8bbc9aa648edd6
Reply
RickeyFight
No I do not see the issue.
The icon  gets smaller when I click on the polygon on the AGOL version but not my downloaded version.
Reply
RickeyFight
Mark Cooney‌ I still have not been able to get the popup to work
Here is my current version
Here is the AGOL version
http://ashlandgis.maps.arcgis.com/apps/Shortlist/index.html?appid=f1481bb8ae024060bd1f76bc5cbad683
Reply
MarkCooney
Rickey,
Did you make any other changes besides the loading indicator?  I do not see the same issue using the same downloaded version: http://storymaps.esri.com/templates/shortlist-2.3.3/?appid=f1481bb8ae024060bd1f76bc5cbad683
RickeyFight
I just downloaded a fresh version and it works as expected. I will look at the code and see what I did to "break" it.
Thank you.
Reply
