Shortlist map change
126
a month ago
MaggieArdito
 I'm just getting back into this. Rupert helped me out several years ago.  Trying to update an underlying map used in several Shortlist Stories.   Earlier Rupert said this:  "the easiest way to find the map used by a Story Map app is to look for your story in My Stories. My Stories will list out the content of any Story Map including the web map(s) it uses. "   but I can't find anything called "My Stories" and the thing called StoryMaps is the new story maps.  Anyway I need to
1.  figure out what the underlying map is.
2.  Update the map in Arcgis Pro and reshare on Argis.com and then fix the story map app to use the updated map...
and can't figure out how to do either of these these.  Help please.
OwenGeo
Esri Frequent Contributor
@MaggieArdito -- My Stories for the classic templates is on the classic storymaps website, here:
https://storymaps-classic.arcgis.com/en/my-stories/
You should be able to find your shortlist story and the web map using this tool.
Owen Evans
OwenGeo
Owen Evans
MaggieArdito
Thank you for this great reply! Yes it works!
