Getting error upon running grunt
228
13
05-14-2018 03:13 AM
MiriEshel
I get this error when I do grunt:
 Error: File to import not found or unreadable: calcite/colors-default.
on line 2 of src/app/components/crowdsource/styles/bootstrap/_crowdsource-calcite-bootstrap.scss
from line 2 of src/app/components/crowdsource/builder/CrowdsourceApp-builder-calcite.scss  @import "calcite/colors-default";
What should I do?
Miri
Reply
StephenSylvia
You'll need to install a different version of Node. The app only support Node v6 or v7.
Reply
StephenSylvia
Did you run the full setup instructions: GitHub - Esri/storymap-crowdsource: The Story Map Crowdsource℠ app enables you to publish and manage..., making sure to install all the dependencies from node and bower? Also, make sure you are using a Node v6 or v7.
MiriEshel
Stephen,
Thanks. I think I installed all the dependencies from node and bower. How can I be sure? I use Node v8.
Miri
Reply
StephenSylvia
Reply
JulieKottamala
Since this storymap is moved to matured support, we want to publish it from our server. However, I get the same error when I try to run grunt. I have node version 6.10 . What else should I check to get around this error? please help!!
Reply
StephenSylvia
What error are you receiving?
Reply
JulieKottamala
Reply
StephenSylvia
It looks like you haven't installed all the dependencies. Make sure you follow the full setup guide before running the grunt task including "npm install" and "bower install": GitHub - Esri/storymap-crowdsource: DEPRECATED: The Story Map Crowdsource℠ app enables you to publis... .
Reply
JulieKottamala
Bower install done too
 This is what I see when I run grunt
Am I missing something? Thanks for looking into this.
Reply
StephenSylvia
It looks like you need to install a git client on your computer: Set up git - User Documentation.
Reply
