Formatting sidebar in Storymap Journal
694
6
10-25-2017 03:44 PM
RamseyJeff
Hi there,
I'm having trouble with the formatting of the sidebar in my Storymap Journal. I can add body style text, then an image with a caption no problem, but then I try to add more body text below the photo/caption and can only add text to the caption!  Even when I try to add another photo below, it ends up getting embedded in the previous caption. Is there a way to jump out of the photo/caption? Pressing enter obviously hasn't been working.
RamseyJeff
Thanks to your help, we've figured out that we've been copying a template where somehow it wasn't working. When we created a new section from scratch, it worked fine. Thanks so much!
OwenGeo
Esri Notable Contributor
Hi -- Pressing ENTER at the end of a line of caption text will keep you inside the caption. Just click below the caption or use the down arrow to exit the caption so you can add more body text or another image.
Owen Evans
RamseyJeff
Thanks for your reply! I've found that unless I already have body text below where I place the image, using the down arrow doesn't work. so I'm left with just ENTER to move down in the section. I was hoping there was a shortcut to jump out of the caption and start new body text.
OwenGeo
Hmm, whenever you add an image in the side panel it should put an extra line of body text after the caption, and I just confirmed this is the case. What browser/OS are you using?
Owen Evans
RamseyJeff
I'm using Chrome. That's funny--there are 3 of us in my group all having the same problem. I wonder what we're doing wrong!
OwenGeo
Jeff -- Sorry, I'm not able to reproduce what you're describing. Could you please provide a few more details about the steps your are following to add the image? For example, where/how are you adding the image? Maybe even post a series of screenshots showing what's happening? That might help us isolate the issue.
Owen Evans
RamseyJeff
